S10 work/hotrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 08:54 PM
S10 work/hotrod
Hi
I am building an 1985 S10 ext cab. It was an X bracket racer. the body is mint and it has had the 350 conversion kit put into it. I got it with no motor/trans. The good, is it has top of the line everything else. It has 4:11 posi rear.
So I got it, now I want to drive it. So I bought an 87 305 flat tappet motor 14101081 heads, 4brl to drop in. (I know it's not a hotrod motor... I don't really want performance... as I have other hotrods for that... but I want a nice driver that is fun and decent on gas.) Looking to push 300hp or close to it.
I have a th200r4 trans. the truck has dual exhaust with headers.
Now I am looking at some bolt on power options... looking for a CAM (bouncing around the idea of SUM 1300, Melling MEL-MTC-1, or Comp Xe252)
Also thinking about mild porting work on the heads. (I think they are decent) Not sure I want to go 1.94 Intake valves. possibly upgrading the heads. if needed.
any thoughts? opinions?
I havin't built a chevy in many years....
Old 06-19-2013, 10:08 PM
vinniekq2's Avatar
for what you are building the guy to talk with id Fbird88. he likes home ported heads on 305s
Old 06-20-2013, 04:47 PM
I have also seen a ton of camel back heads popping up around here.... If I can find some without 2.02 valves maybe they's be a better start than the 081 heads??
Old 06-20-2013, 05:23 PM
techinspector1's Avatar
Wiki Edits: 326
Camelbacks will most likely have 64cc chambers that will lower your static compression ratio without a piston change and I don't think the 305 bore will accomodate the 2.02" valves. You're pretty much stuck with what you have to work with in my opinion......until you upgrade to a 4.000" block.
Old 06-20-2013, 06:02 PM
Banned
hey let's see this mint bodied beast! post some pics!
will a 4.3 from a 92 s10 work in a 1999 blazer? bshafer1989 Hotrodding Basics 2 03-14-2013 07:07 AM
S10 355 brakes don't work very well ttjsk812@aim.com Suspension - Brakes - Steering 12 07-22-2012 10:28 AM
will stock drive shaft work with 700r on longbed s10 s10ryder Transmission - Rearend 2 05-23-2007 08:00 PM
s10 to hotrod rickburks Introduce Yourself 2 11-23-2006 06:22 AM
non hotrod question for you guys who work for a living... crazy larry Engine 10 10-08-2003 06:55 PM
