s15 tbi 2.8 swapped to carbed 350 gas gauge hook up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 03:13 PM
mean s15
Hey guys I need help with my gas gauge. It worked before the swap but I think it runs on the same circuit as the ecm, I took those fuses out along with the computer. Correct me if I'm wrong but isn't the fuel gauge connected with the pump? I already ran out of gas with this beast trying to get things back in order. Thanks for any input
Old 04-27-2011, 09:40 AM
mean s15
Alright would it be easier to hook up a after market gas gauge?
Old 04-27-2011, 07:03 PM
mean s15
gas gauge
Old 04-28-2011, 11:31 AM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
The '94-'01 model years did not use the PCM for the fuel gauge.
The instrument cluster will need to be powered 12+ for the fuel gauge to work.
The fuel pump and the fuel level sensor have a common ground at the tank. Make sure this ground is good.
vicrod
Old 04-29-2011, 07:37 PM
mean s15
fuel gauge
It's a 87 s15 pick up
Old 04-29-2011, 08:08 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
So you have three wires, Hot for the pump, ground for the ground and the third wire is the fuel level.
It should run to the gauge and the gauge should have a hot wire.
Old 04-29-2011, 09:40 PM
willowbilly3's Avatar
Last journal entry: Body mods
On those older S10s the gauges all grounded on a screw at the bottom left side of the dash. The gauges would go all wacky if the screw got a little loose.
Old 05-01-2011, 07:06 AM
mean s15
gas gauge
Yeah that's exactly what it does. It acts like its working sometimes but not sure if its reading fuel level or just a wacky ground. Going to fiddle with it and see thanks everyone.
Oil and temp gauge hook up? truckboy61 Engine 7 07-11-2010 10:20 PM
Oil pressure gauge hook up truckboy61 Engine 5 04-21-2010 04:46 AM
78' SBC oil pressure gauge hook up spot on block 85-monte Engine 6 05-11-2008 11:12 PM
oil pressure gauge hook up meev182 Hotrodding Basics 6 06-30-2006 01:15 PM
Volt Gauge hook-up 66pontiac Electrical 2 09-12-2005 06:51 PM
