Saab head, Ford block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2013, 02:21 PM
techinspector1's Avatar
Wiki Edits: 326
Does anyone know if a Saab 2.3 DOHC head bolt pattern is the same as the Ford 2.3 SOHC? Will the Saab head bolt onto the Ford block?
Old 11-13-2013, 02:26 PM
Banned
are you talking about the Volvo/ford head swap?
I believe some saab parts swap in place for some ecotec parts but never heard of ford.
Old 11-13-2013, 04:15 PM
BOBCRMAN@aol.com's Avatar
Saab and ecotek are interchangeable in the later GM owned years..
Never heard of Saab/Ford interchange. But this is/was GM country
Old 11-13-2013, 04:50 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Honestly I don't know other than they are both 10 bolt heads. Here are a few links to sites that say they will, you may want to ask them over there?
Saab doch head? - Turbobricks Forums
Yahoo Groups
From what I can find it may work, but the general feeling is it wouldn't be any gain? I am just reposting what I have read, because I honestly don't know. I do know you can get big power out of a 2.3 Ford if you don't mind throwing some money at it. We ran one for a few years at a local dirt track and it held up turning 9400 in the straights for 2 years before we started running a late model.
Kelly
Old 11-18-2013, 06:49 PM
its a 16V DOHC Volvo head that fits on the ford 2.3. Requires custom manifolds and stuff tho. Easily confused tho, since Saab and Volvo are both Swedish cars...
Old 11-19-2013, 08:25 AM
Wiki Edits: 27
head swaps?
The torque plates we used when reboring engines would fit several engines, head bolt spacing was the same, The centerline dimensions for engine manufacturing machinery were for several engine families. It Is very expensive to develope a new engine and have to buy all new machinery.
Old 11-19-2013, 08:29 AM
Wiki Edits: 27
old gm-ford swap
I used to live next to a guy that raced 4 cyl circle track super modified . For a while he ran a Boss 302 head head on a GM iron duke block. then he started sawing SBC V8 blocks in half, welding them back together to have a V 4,
Cracked head or block in 460 Ford marine Jetrocker Engine 2 12-20-2011 04:31 PM
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
Head Bolt Torque (ford-y-block) W.THERIAULT Engine 1 01-15-2007 04:11 PM
saab oil pressure? 66ord Engine 2 01-11-2007 02:01 AM
Ford Small block cylinder head ID roys63 Transmission - Rearend 2 11-02-2003 05:58 PM
