Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Saab Turbos on SBC
  #61 (permalink)
Old 05-13-2010, 10:03 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by ap72
Well, you'll need a valve job with a new seat, and since you're doing that you may as well get new valves... cheapest "I just need it done" solution is going to be around $100. To go with larger valves and have all the seats done to match along with some bowl blending- $500.
Can he avoid putting in a new seat by moving up a valve size? Often this can save it. It costs a little more but you end up with larger valves- you gain something from your expense rather than just making it as good as it was before.
Unfortunately no the seat is already cut out. I planned on doing new valves anyways but i will probably just stick with the 1.94 x 1.5. I can do the valve job myself and also the bowl blending so i wont have to worry about cost there. So im sure they are going to clean the head up, mag it, and the just hopefully install the one seat.
