Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Saab Turbos on SBC
  #69 (permalink)
Old 06-10-2010, 12:40 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by TurboS10
If the map that is posted is correct it shows max flow around 15lbs of air per minute. Rule of thumb is 10 hp/lb, but sometimes you can get a little more. However, I suspect that map is not correct for what you have. Do you know the factory rated HP of the engine it came on?
it was discussed earlier in the thread i think right around 200hp but that was at 7psi
