Saab Turbos on SBC - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-07-2010, 08:06 AM
Banned
Originally Posted by zildjian4life218
Well yes the compressor plays into it but I was talking about the turbine "Hot" side. The flange is only T25 but i guess all i can really do is try it and see what happens.
it is small. faster spool, earlier cut off. port the entrance out the best you can with some cartridge rolls (not bigger, just smoother like a cylinder head), and the waste gate, never go over 5000 RPM and you'll be fine.
  #32 (permalink)
Old 05-07-2010, 08:09 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Im prolly gonna run a tpi intake too so this might be a good combo. From what I have read those intake start packing up around 5000rpm but make good torque down low. Throw in a mild RV cam with some overlap and voila.
  #33 (permalink)
Old 05-07-2010, 08:27 AM
Banned
NO RV CAM. you'll want a single pattern, RV cams typically have a 10 split. It'd make a hell of a combo with a TPI intake, or a converted LT1 intake. you'll need bigger injectors though. not grossly bigger but about another 10 pounds/hr.
an ideal cam would be something like a summit 1069 cam.
You need to put this thing together and tell me about the amazing passing power on the interstate.
  #34 (permalink)
Old 05-07-2010, 08:32 AM
Listen and Learn
Wiki Edits: 7
I never knew that about the RV cams. Lol wow that is a low rpm cam. Perfect for this setup though.
So this is what I have right now. A 76-79 305 Truck block with stock 12.5cc dished pistons. Stock rods and crank also. I will go through and do bearings and rings.
I also have the TPI intake. Its off of a 86 305 camaro so its the pre '87 style cylinder heads. I believe they are 22lb/hr injectors.
I don't have a set of heads that will yield a small enough compression. I have 2 sets of 60cc heads, a set of vortecs that will not work, and a set of 882s.
  #35 (permalink)
Old 05-07-2010, 09:01 AM
Banned
how low of compression are you wanting?
Go with 30 or 35 pound injectors.
  #36 (permalink)
Old 05-07-2010, 09:02 AM
Listen and Learn
Wiki Edits: 7
I was shooting for 7.5-8.0:1
  #37 (permalink)
Old 05-07-2010, 09:20 AM
Banned
you need a 70cc chamber... port the runners the best you can on the 882s and run them. They're not a great head but you have to keep in mind your required flow isn't huge.
  #38 (permalink)
Old 05-07-2010, 09:31 AM
Listen and Learn
Wiki Edits: 7
alright cool. Should I mill the heads some to get them down to the 70cc? Also I thought the 1.94 x 1.5 valves are too big and will hit the bores of the 305?
  #39 (permalink)
Old 05-07-2010, 09:37 AM
Banned
they aren't too big, but they are close. 194 is as large as you can go. DOn't mill the heads- they're already thin, and you'll just have to run more boost to compensate, crank it up to 13-15psi. Now you're looking at 475hp... dang... Just be sure to clean up the exhaust and intercool it like I have mentioned several times, its VERY important to keeping heat down and making this thing live.
  #40 (permalink)
Old 05-07-2010, 09:41 AM
Listen and Learn
Wiki Edits: 7
Lol ill be at 7.25:1 with the following
76cc heads
12.5cc pistons
3.736" Stock Bore
Gasket - .030" x 4.200"
Deck Clearance - .025"
Stroke - 3.48"
Will that be alright or is that too low?
  #41 (permalink)
Old 05-07-2010, 09:50 AM
Banned
76cc heads
12.5cc pistons
3.736" Stock Bore
Stroke - 3.48"
I'd run a thinner gasket. a felpro 1094. .015" thick. Also have your heads surfaced, it'll drop about a cc or two.
  #42 (permalink)
Old 05-07-2010, 12:30 PM
Listen and Learn
Wiki Edits: 7
Alright cool that will sit me at about 7.5:1 This should be a fun little torque monster. I had 2.41 gears in my cutlass. I wonder how this would have done with those gears.
  #43 (permalink)
Old 05-07-2010, 12:32 PM
Banned
anything more than about a 3.55 gear is too much for this type of engine.
  #44 (permalink)
Old 05-07-2010, 12:39 PM
Listen and Learn
Wiki Edits: 7
I like the long pull of a real high(numerically low) gear. I had 2.41s in my car and they were fun. Went from 1st to 2nd at 85mph turning 6500rpm. Maybe ill put a 3.08 behind this setup
  #45 (permalink)
Old 05-07-2010, 07:36 PM
Last journal entry: it can roll now
Carb will need to be converted to blow through. Or go fuel injection. How much boost was it making? How did the turbos spool and at what rpm?
Thanks for the info,i wish that was a cheap fix because im not really interested in putting any money into this just so it witll work. im not really sure on exact numbers because i dont have gadges or anything hooked up but i would say it really starts to spool around 2500-3000 but not sure how much boost it has but do know it has enough that it would make a huge different if all if it was blowing in for sure. hope your project works, good luck
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
Just another Saab story... freebie though ViperMonster800 Transmission - Rearend 2 05-01-2006 11:35 AM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 02:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
