Saab Turbos on SBC - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 05-20-2010, 05:06 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I attached a dyno sim of this build. To open it download it and unzip it. Then save it to desktop or wherever. Then open desktop dyno and go to open then navigate to where you saved it to. Tell me what you think. The turbo I used there is not the exact turbos im running but i got a compressor map and typed in the surge and island flow for the garret turbos used on the saabs.
File Type: zip SBC305TT.zip (880 Bytes, 90 views)
  #62 (permalink)
Old 05-23-2010, 07:56 PM
Listen and Learn
Wiki Edits: 7
anyone have any input?
  #63 (permalink)
Old 06-07-2010, 04:42 PM
Listen and Learn
Wiki Edits: 7
I uploaded another dynosim if anyone can take a look at it that would be great. I got a compressor map for a Garret T25 "45trim" turbo and put in the actual specs for the turbo using the island and surge flow for 2 turbos.
This might end up being a very cheap build. Turbos are $50 a piece and i have 5 or so 305s laying around.
Heres what I get with a pr of 1.82 or about 12psi:
RPM HP TQ
2000 145 380
2500 193 405
3000 258 451
3500 316 474
4000 374 491
4500 428 499
5000 472 496
5500 496 473
6000 502 439
6500 485 392
File Type: zip SBC305TT.zip (870 Bytes, 73 views)
  #64 (permalink)
Old 06-08-2010, 03:39 PM
Listen and Learn
Wiki Edits: 7
bump anyone?
  #65 (permalink)
Old 06-10-2010, 08:43 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
My input would be that those dynos are about 80% at best. The turbos will work on your engine up to 350 HP range max if that map is correct...300 is more like it. However, since it is "hand drawn" I would not trust it and would look for a garrett map.
Next, junkyard turbos are great; I have done three different junk yard turbo build. Most people on the internet today talking about turbos know very little about them, and..... Last piece of input is that most people "overturbo" an engine, so for best results match everything well.
  #66 (permalink)
Old 06-10-2010, 10:05 AM
Listen and Learn
Wiki Edits: 7
Originally Posted by TurboS10
the turbos will work on your engine up to 350 HP range max if that map is correct...300 is more like it.
really that low? i figured 500hp was out of the question but 400-450hp would be nice.
  #67 (permalink)
Old 06-10-2010, 11:38 AM
TurboS10's Avatar
Wiki Edits: 2
If the map that is posted is correct it shows max flow around 15lbs of air per minute. Rule of thumb is 10 hp/lb, but sometimes you can get a little more. However, I suspect that map is not correct for what you have. Do you know the factory rated HP of the engine it came on?
  #68 (permalink)
Old 06-10-2010, 11:40 AM
Listen and Learn
Wiki Edits: 7
it was discussed earlier in the thread i think right around 200hp but that was at 7psi
  #69 (permalink)
Old 06-10-2010, 11:57 AM
TurboS10's Avatar
Wiki Edits: 2
[QUOTE=zildjian4life218]it was discussed earlier in the thread i think right around 200hp but that was at 7psi[/QUOTE
If that is correct, then you should be able to push 250 each out of them. Most manufacturors design a margin of error and try to keep the turbo in the safe range of the compressor. However, you can usually safely get more. The only way you will know for sure is to find out exactly what they are and get a compressor and turbine map for them. To discuss without those things is pure speculation.
  #70 (permalink)
Old 06-10-2010, 05:53 PM
Listen and Learn
Wiki Edits: 7
[QUOTE=TurboS10]
This is better.
  #71 (permalink)
Old 06-10-2010, 08:14 PM
TurboS10's Avatar
Wiki Edits: 2
That is a little more, but still shows it fully maxed out at 20lb/min. If that is true, 450 with the pair is about the best you could hope for.
  #72 (permalink)
Old 06-10-2010, 08:24 PM
Listen and Learn
Wiki Edits: 7
That will be fine for what I am doing. This is more of a throw it together and see if it works kinda deal. I would be more than happy with 400-450hp. I am thinking about putting this in an s10 with a 4speed m-21 and maybe like a 3.08 rear gear. Ill try to post some pics soon. I have one turbo just waiting for the yard to get another saab. Usually there are 4 or 5 there but now that I have a possible use for them they aren't in sight.
  #73 (permalink)
Old 06-10-2010, 08:58 PM
TurboS10's Avatar
Wiki Edits: 2
PM me with a picture of what you are looking for. I have one on the shelf in my shop, but there are several variations on the little garretts.
  #74 (permalink)
Old 06-10-2010, 09:08 PM
Listen and Learn
Wiki Edits: 7
I will post the model and serial numbers tomorrow I don't have the turbo in front of me. I know its a T25 .42(cold) and .48(hot) ar and i believe its the 45 trim version not 100% sure though gotta measure it this weekend.
  #75 (permalink)
Old 06-12-2010, 05:40 PM
Listen and Learn
Wiki Edits: 7
A little update on the build. My machinist GAVE me a set of forged vernolia either .030 or .040 over 305 pistons. They are domed pistons but have a solid dome so we put two on the lathe and cut them down to flat top. My cr should still be around 8:1 if I put a little thicker head gasket on it and unshroud the valves. I am trying to figure if I want to run a TPI or LT1 converted intake on it. I have both intakes sitting on my shelf just not sure which would be better. Either one I could run megasquirt and I will need injectors for either. I keep forgetting to take pictures as I make progress. Looks like ill be boring the block over too.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
Just another Saab story... freebie though ViperMonster800 Transmission - Rearend 2 05-01-2006 11:35 AM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 02:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
