Saab Turbos on SBC - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 07-25-2010, 09:42 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Very, very goo grasshoppa....now I show you calcula5tor to do math for you :
http://www.turbofast.com.au/javacalc.html
Now that you understand the math you can plug things in to the above listed calculators and actually understand what you are seeing.
There are some points to consider. First, you are only calculating peak RPM. How much are you going to operate at full power? Second if you run those numbers again for the same boost numbers at 3500RPM and I think you will find that it is about perfect. How much time will you spend around this range? Third, the map does continue and if you continue the lines you can see it will be right at the edge, but will in fact still feed the engine sufficiently.
My point in all of this is if it is a street car, it will work very nicely and spool instantly which will make for a very fun ride.
I also dont disagree that they are a little bit small, but not much.....in the end it comes down to what you are wanting to do.
  #92 (permalink)
Old 07-28-2010, 08:32 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Thanks for the link. I made an excel chart with the same idea as the above link just not written in java script. where on one side you put in the constants and it outputs on the right. Oh well at least i now know what the formulas do. Thanks for all your help everyone. I am waiting to get sometime so i can go down and bore my block. The forged pistons my machinist gave me are .030 or .040 over so gotta punch out the block.
  #93 (permalink)
Old 08-19-2010, 09:08 AM
Listen and Learn
Wiki Edits: 7
Any idea what I should gap the rings too. I got some enginetech El cheapo rings. Just putting some dished stock pistons back in it. I'm having a hard time believing this is gonna make over 400hp with the t25 turbos. Later ill build a 305 with the forged pistons I got and bigger turbos. I put the top ring in and its sitting at about .020. Thanks for all the help and support.
  #94 (permalink)
Old 08-19-2010, 09:19 PM
Listen and Learn
Wiki Edits: 7
Anyone any ideas on the ring gap? Stock bore 305. Gonna be running 12-15lbs
  #95 (permalink)
Old 08-30-2010, 08:10 AM
Listen and Learn
Wiki Edits: 7
Well I went to keith blacks website and used their calc for ring gap. I put the top ring at about .028" and the second ring at .030". The calc said .026" and .028" but i would rather things be on the loose side as opposed to the tight side.
  #96 (permalink)
Old 08-30-2010, 08:16 AM
be sure to get the incoming charge as cool as possible. heat soak is a problem with smaller turbos, but isn't a big deal if you cool down the charge.
  #97 (permalink)
Old 08-30-2010, 09:31 AM
Listen and Learn
Wiki Edits: 7
I will definitely be running an intercooler and possiblly a Meth injection setup
  #98 (permalink)
Old 09-05-2010, 01:06 PM
Listen and Learn
Wiki Edits: 7
The short block is all together. I will be ordering the cam soon hopefully and then I can degree the cam, put the timing cover on, and the oil pan.
For those of you who are observant you probably noticed that piston 1 appears to be in backwards due to the dot on the piston facing the back. It was for the even side but the only piston I had left. I had a pile of pistons from two different 305s. One came apart so most of it was junk. My machinist said the orientation on the pistons doesn't matter for that style heads just the rod orientation does which is correct.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
Just another Saab story... freebie though ViperMonster800 Transmission - Rearend 2 05-01-2006 11:35 AM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 02:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
