Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-17-2009, 12:56 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Saab Turbos on SBC
I went to my local u-pull today and there are two saabs there with turbos on them. They are 2.0 liter engines and my friend said he thought that the flanges were T25. Do u guys think these would work on a twin turbo low rpm sbc. I want to build a low rpm engine that will prolly have a 5000rpm redline on it built primarily for torque.
Old 10-17-2009, 01:33 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Without compressor maps there is no way to guess. Using junkyard turbos isn't a guess kinda thing. Its like building a complete engine then putting in a cam with unknown specs. The chances of it being a good match are very slim. They can be modified within a certain narrow range, but that might be just as expensive as buying the right turbo to start with.
Old 10-17-2009, 02:23 PM
matt167 matt167 is offline
Wiki Edits: 31
if there cheap enough just pull them. it's not likely they'll be big enough, but in any case, you'll make money putting them on Ebay.. an HX-35 from a dodge Cummings diesel would be good
Old 10-17-2009, 03:59 PM
joe_padavano joe_padavano is offline
If the turbo is sized for a 2.0 liter engine, then two of them will still be too small for an SBC.
Old 10-17-2009, 11:40 PM
Listen and Learn
Wiki Edits: 7
i had a feeling that they would be too small. so what turbos would work, the one off the cummins? i want to build a low rpm turboed motor for torque.
Old 10-18-2009, 04:38 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Look at how much horsepower the Saab motor makes. How about four of them turbos on a 350SBC. "Now you're cookin' with gas"
Old 10-18-2009, 08:05 AM
Listen and Learn
Wiki Edits: 7
LOL. 4 turbos that would be neat but kinda expensive. The one book i have on turbo charging has a truck with 12 of them on it!
Old 10-18-2009, 10:05 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
You can calculate if those turbos are going to work rather easily, if not too precisely.
Two simple ways to do this.
Donor engine rated Hp
divided by the number of turbos on it.
multiplied by the number of turbos you will run
equals the estimated Hp you will support.
SO
donor motor rated at 280 Hp
divided by 1 turbo equals 280 Hp
times the number of turbos you will run (2)
equals 560 Hp
this is assuming that the fuel types in both engines are the same (gasoline to gasoline or diesel to diesel).. not that you can't use a diesel turbo on a gas engine, just that this method leave a little to be desired.
a slightly more accurate way if you are mixing and matching is:
Donor motor one size, 2.0 liter times Redline RPM (6000 rpm?) = 12,000
divided by the number of turbos (1) = 12,000
Receiver motor size, 5.0 liter times redline rpm (5000 rpm) = 25,000
divided by the number of turbos (2) = 12,500
12,000/12,500 = .96 or 96% chance of being correctly sized.
keep in mind that this is assuming your target boost pressure is approx the same for the receiver as what the donor motor was expected to handle.
and is a very rough way of determining if the turbo will work. If both of these calculation say the turbos will work, they will work. they may not be the best fit but they will fit and make the horsepower that step one says +/- your engines efficiency vs the donor motors efficiency.
Old 10-18-2009, 10:08 AM
Listen and Learn
Wiki Edits: 7
thanks for the post nxs. I will find out how much power those motors are putting out from the factory. I knew it would be close weather they would work or be too small but i figured if i built it for a low rpm engine maybe they would work.
Old 10-18-2009, 10:15 AM
Listen and Learn
Wiki Edits: 7
from what i got online they were putting out about 185hp.
Old 10-18-2009, 10:33 AM
Wiki Edits: 31
That way of checking is not in any way accurate... no way will 2- 2.0L Turbo's support 560 HP on most any V8, exceptions would be the late 70's - early 80's Emissions V8's that Ford and Chevy put out. 255,267,265 ect.... there sized to 2.0L 4cyls so 2 would be sized correctly for like a 4.0L V6, then the support for 560 HP would stand... but the real accurate way of checking involves a boost map because they factor everything
Old 10-18-2009, 11:06 AM
Listen and Learn
Wiki Edits: 7
someone mentioned an hx-35. would two of these be a better setup for my build?
Old 10-18-2009, 11:19 AM
NXS's Avatar
NXS NXS is offline
Matt,
Those are just examples...
and for the record i have a turbo that fits 2.0 liter motors that makes 600 hp...
But that's beside the point. In the examples i gave i just used some fictitious numbers....
Let's look at what he has and has found.
saab 2.3L rated at 185 Hp @ 5500 rpm.
I assume (b/c OP didn't correct em) he has a 5000 rpm 305 215 hp?
SO
donor motor rated at 185 Hp
divided by 1 turbo equals 185 Hp
equals 370 Hp
Donor motor one size, 2.3 liter times Redline RPM 5500 rpm = 12,650
divided by the number of turbos (1) = 12,650
12,650/12,500 = 101.2%
a 1% chance of being incorrectly sized (too large)
going further with this:
http://www.saabnet.com/tsn/models/2001/pr7.html
The Saab 9-5 Sedan's 2.3L light pressure turbocharged engine uses relatively low boost pressure (maximum boost of about 8.0 psi or 0.55 bar) to deliver boost quickly,
so the turbo's are meant to last 100K miles with 8.0 psi.
so we know those turbo's (2) push 380 hp worth of air at 8 psi
8/14.7 = 0.544 + 1 = 1.544
1.544 * 215 = 332 Hp @ 8psi
332/ 370 = 89.7%
by horse power/boost an 89.7% chance of being the correct size (10% chance of being too big).
if i take 1% and 10% / 2 equals a 5% chance of being too large,
now I'm ready for you to pull out the maps and show me what they say. i'll be waiting.
Old 10-18-2009, 11:59 AM
NXS's Avatar
NXS NXS is offline
here is the map and associated points for twins on a 215 Hp 305
Old 10-18-2009, 01:02 PM
Listen and Learn
Wiki Edits: 7
Question on the compressor maps. So the closer i am to the middle circle the better matched the turbo would be for my build correct? As of now i am thinking about putting it on a 305, cause i have 3 or 4 sitting around and need to build or get rid of them.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Saab Turbos on SBC"
ThreadThread StarterForumRepliesLast Post
Long Awaited 400 SBC Dyno ResultsMad MaggotEngine1910-14-2011 08:29 PM
Just another Saab story... freebie thoughViperMonster800Transmission - Rearend205-01-2006 12:35 PM
sbc 350/400 heads helpJwhiteEngine609-04-2005 06:56 PM
oil drain on SBC headsTerroRx7Engine703-17-2005 03:12 AM
Late model 350 SBC QuestionSmoker113Engine302-19-2005 11:12 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
