Sadie - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2010, 09:42 PM
Sadie
Car cranks easy when cold, drive for a short while, turn car off and try to recrank it and car turns over slowly and won't crank until it cools,I changed the battery, starter,coil,wires,plugs.What could it be I even put a high torch mini starter that can crank 18-1 compression engines but no winner.Should I try the module or better coil(more voltage) it's a chevy 350/w HEI stock ignition
Old 12-26-2010, 09:57 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
you may even wana check the timing sometimes if the timing is off it will crank slow when warm
Old 12-26-2010, 10:09 PM
tryied it
change the timing retard it will crank but back fires have to turn timing back up to get my power theres no perfect spot on the timing
Old 12-26-2010, 10:25 PM
sqzbox's Avatar
My pipes are my music
What shape is the + cable from the battery to the starter in? I had that problem after buying a used F-bird and found the cable had been spliced. Sounds like a voltage problem to the starter.
Old 12-26-2010, 10:30 PM
O.k.
I looked at the cable when changing the starter but not the whole cable just what I could see it's long and goes under the oil pan and runs around somthing but I will replace just to see would it cause this problem after it's already cranked good
Old 12-26-2010, 10:33 PM
35terraplane's Avatar
sadie
Could be a bad ground too. check both cables, both ends.
35terraplane Bob
Old 12-26-2010, 10:36 PM
sqzbox's Avatar
Originally Posted by 35terraplane
Could be a bad ground too. check both cables, both ends.35terraplane Bob
Good idea. Good clean connections are needed at both ends. The starter has to work harder to crank a warm engine. Weak voltage to the starter will cause your problem. Universal battery connectors are bad about that as the wire going in can corrode bad. side mount battery connectors are culprits also as they corrode inside where you can't see it.
I ran a new ground from batt. to the block and frame it's diving me crazy or I should say it's not driving me at all
