| View Poll Results: Which is better SAE or Metric? | |||
| SAE |
7 | 36.84% |
| Metric (SI) |
12 | 63.16% |
| Voters: 19. You may not vote on this poll | |||
LinkBack | Thread Tools |
What?
what kind of car are you working on? |
I just saw your poll, the quality does not measure out to the bolt type, it measures between the bolt grade, it only depends on what kind of car you are working on, cause threads will not mate up. there is no comparison
Metric sucks. This is the USA where we measure things in inches, feet, yards, and miles. Let the Europeans and Japs measure things the way they want. Here we use SAE.
I think he's after which we like better, SAE or Metric. Personally, I prefer SAE, but more often that not, those metrics fit a rusty nut (with a bit of Big Freakin' Hammer persuasion) better than an SAE.... In a while, Chet. |
If someone can't name the socket sizes between 1/4" and 1" he needs to go back to school! I have absolutely no trouble figuring out which SAE socket size I need and I don't EVER remember needing a half size
What will piss you off to no end is working on Oh say a 85 Chevy Suburban where SAE & METRICS ARE EMPLOYED
They just couldn't make up their minds back then Don't matter much to me I have complete sets of both & then some Just gots to keep a eye on those precious metals!!! R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Yea, metric sucks but we just have to grin and bare it I guess. But, if someone says you can only have one set of wrenches either sae or metric, I'd have to go with metric because metric will fit sae but sae will not fit metric, go figure. So if you can only afford one set of wrenches and one set of sockets metric would be the choice. Cheers!!!
I can't work efficiently on assemblies using fasteners sized using metric units because my crescent wrench won't fit the fasteners . Vise grips also are designed to be used with AMERICAN sizes. Now because of the many inadequacies of the metric system I have to make compensations when I'm putting metric stuff back together. I have found through much empirical testing that a 3/8" bolt pounded into a hole sized for an 8mm holds like there is no tomorrow. Hammers work with any measurement system. Except whitworth. Just my opinion so I'm sure it's wrong, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-07-2006 at 08:43 PM. |
| Recent Garage - Tools posts with photos |
| Imperial or Metric? | Nightfire | Garage - Tools | 26 | 06-11-2005 09:38 AM |
| metric flared brake nuts | cboy | Suspension - Brakes - Steering | 6 | 03-14-2005 12:08 PM |
| Brakes lines usa to metric | brainsboy | Suspension - Brakes - Steering | 4 | 10-29-2004 11:59 AM |
| NET and SAE Horsepower? | tommeide | Engine | 4 | 11-30-2003 02:27 PM |
| AOD Metric | mustang66maniac | Transmission - Rearend | 4 | 08-05-2002 10:52 PM |
