Is This Safe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 12:45 AM
Is This Safe?
is 37" of braided fuel line too much to run before the pump? 12 gal cell outlet pointing rearward, not a sump, Holley blue pump definitely below lowest point of cell, all -8 An. line. Its mocked up now, I bent the tape measure along the line closely as possible so this is + - an inch.
Thanks guys
Old 06-15-2010, 01:24 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Safe? Sure, as long as you're talking about real, genuine stainless braided line and not that Fosdick stuff that is just a cheezy covering for cheapo rubber fuel line. Hell, you can plumb the entire car front to rear with stainless braided line, depending on the thickness of your wallet.
Old 06-15-2010, 10:25 AM
406 bug's Avatar
9.82 @ 139mph
As Tech sez, don't worry bout the length. Its the size of the line inside. My system in 100% braided, from cell to carb. 3/8 id is good.
Old 06-16-2010, 04:13 PM
Thanks you guys. I wasn't too clear, I meant "safe" for the fuel pump, they can only have so much line before them before failing quicker?
Old 06-16-2010, 05:25 PM
406 bug's Avatar
9.82 @ 139mph
So long as your pump is lower than the tank , the pump can't tell how long your line is.
Old 06-17-2010, 02:20 PM
Thanks Bug
Old 06-17-2010, 04:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
As long as when (more like IF) you were to remove the pump from the end of the three foot run of hose, that fuel would flow out by gravity alone, it'll be OK. What you want to avoid is where the pump would have to "pull" fuel from the tank against gravity- it works much better "pushing" the fuel, w/a gravity fed inlet.
Rat Rods can be safe. Paddington Introduce Yourself 8 09-27-2009 09:53 PM
safe load ratings for "big-little" tire combo 471A Suspension - Brakes - Steering 2 11-25-2008 11:29 PM
safe to post to journals modas Hotrodders Site Suggestions and Help 1 06-21-2005 10:37 PM
Are WHEEL SPACERS safe? MuscleBlock81 Transmission - Rearend 14 01-27-2004 11:19 AM
is it safe to redrill steel wheels? swoodard23 Engine 12 10-12-2003 04:09 AM
