safe bore of 292 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 09:29 AM
safe bore of 292
Building a '67 Sportside P/U
Building a 292 Turbo, Injected on E85 and Laughing gas
What is the safe bore of this engine?
Starts with a 3.875
Can it go to 4?
Old 09-16-2012, 10:44 AM
vinniekq2's Avatar
are you talking a 60 over 283 or the 292 inline 6?
Old 09-17-2012, 10:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm gonna go out on a limb here and say you're talking about a Chevy inline 6 and not a SBC or FoMoCo V8.
Starts with a 3.875
Can it go to 4?
Very unlikely. You can get a 0.060" overbore safely in most cases, but pushing it to 1/8" is risky and I wouldn't even think about trying it w/o a sonic bore thickness test to see how much material there is in the block- and where the material is located (thrust side of bore or not, for example) due to core shift and manufacturing tolerances.
If this is a drag only deal, you might consider a partial fill of HardBlok to stiffen the block, but even then, at 0.125" over, there's just not going to be enough bore thickness IMHO.
If you're boosting it, forget about pushing the limit of bore size. What you need is a stiff bottom end.
Old 09-17-2012, 12:25 PM
Agreed with cobalt327. However, in the '70s, we built a 250 and bored it .125" over and it was fine. A sonic test WOULD show what you need to know.
Just went through a 292 for a work truck. .060" over was the largest available.
Jim
Old 09-17-2012, 01:14 PM
"Olde Gear Head"
Thanks to all who replied
Yes, it's an L6 not V block
6 sleeves whould be a little extreme but not crazy, RIGHT?
Old 09-17-2012, 10:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Is there a reason other than a displacement increase for you wanting to go to a 4" bore?
Spread bore manifold & square bore carb? 383SBC Engine 2 04-09-2012 10:21 PM
Spread Bore VS Square Bore Advise daveh Engine 22 01-05-2012 07:35 PM
Edelbrock square bore to spread bore GUITAR1989 Engine 15 08-01-2011 07:04 AM
can you bore a 283 block out to a 4" bore ? Mustangsaly Engine 13 05-01-2007 04:02 PM
Spread bore with square bore carb western star Engine 5 10-28-2004 02:16 PM
