Safe heater position for painting? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-21-2007, 05:35 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
[QUOTE=Rob Keller]I think you heater should be close to the ground.
Heat rises.
Your right Rob....heat rises....but fumes settle to the floor, thats why they recomend that any shop heater should be at least 18 inches above the floor. When I got out of the service I worked in a paint manufacturing facility. They had gas heaters like cboys mounted near the ceilings...the lights and light switches were explosion proof ( sealed air tight) . Any way those heaters ran while we were mixing solvents and resins making paint....never a problem. The way I do in my shop...I have infra red heaters....I warm things up good, turn off the heat , shoot the paint....wait awhile for the fumes to settle and then go back with the heat.
  #17 (permalink)
Old 11-21-2007, 09:17 PM
cboy's Avatar
Last journal entry: Finished
Do you see any problem with Dan's idea of running one or two baseboard type electric heaters during the actual mixing and shooting?
Always learning...and sharing what I've learned.
  #18 (permalink)
Old 11-22-2007, 05:03 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There should be nothing in those electric baseboard heaters to ignite the fumes. The heating element is encased in a ceramic tube and surrounded by aluminum fins. You should be able to have them going while you're mixing and painting. Check with an electrician, Dewey.
  #19 (permalink)
Old 11-22-2007, 09:48 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
[QUOTE=Henry Highrise]
Heat rises.
If I ever get a shop.
The distance of my heater Give or take is ,91 to 94.5 million miles away!
I know but Its better to be a Smart Arse than a Dumb Arse!
My thoughts; Not being, a electrician is that Radiant Heat/ Infrared Heat would be the way to go .
Just be careful & aware of the switching devices .IE: Pilot lights & thermocouple switches.
Heating the objects in the area will also heat the air & create air flow circulation.
Any thing that MIGHT create a spark in a Volatile environment!
Even a Static spark .
Remember dust will explode given the right set of circumstances.
I wonder if sanding dust will burn if enuf piles up?
Henry 's way has to be the safest .
Rob
"SlowRide66"
"Illegitimis non carborundum"
  #20 (permalink)
Old 11-29-2007, 12:20 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
After screwing up a paint job last winter because of the cold, I resigned myself to painting ONLY when it was 60 or higher. Makeup air is cold. It cools metal off FAST. Leads to irregular curing, IMO, and results in orangepeel.
Or , see if you can rent a booth.
I made such a mess of my shop, it made me sick. I masked everything off, wet the floors, you name it. I shot red and white single stage. Guess what color my floors were? And my tool boxes, and the walls behind the mask. That crud gets EVERYWHERE.
One word to the wise. If you insist on using your shop, buy some sprayable paint mask, like they use in booths. Spray the floor. When you are done, it peels right up.
  #21 (permalink)
Old 11-29-2007, 04:24 PM
Rob Keller's Avatar
Wiki Edits: 38
What is this sprayable paint mask that YEE speakth of?
R
"SlowRide66"
  #22 (permalink)
Old 11-30-2007, 01:51 PM
Thine spray mask may be procured through any one of thine local autorefinishing purveyors. A multitude of suppliers sit waiting by thier monitors just waiting for a googlesk type individual to find them, and purchase their wares.
(Can NOT think of the name of the magazine that comes to me. AutoRefinish Mart, or something like that? Comes quarterly. Several local supply houses tout it as better than sliced bread. )
  #23 (permalink)
Old 12-07-2007, 09:46 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
We used to use it in spray booths and I think it was called PeelRite or Peel-E-Z. I can't remember which. But that was a few years ago. If you use a BC/CC, the paint will cover things but it is more of a dust. The clear will definately leave an overspray. Single stage will and does cover everything. Get a roll of Sharkskin plastic. It's about $35.00 for a 12' x 400' roll. It is the thin painters plastic. Use it to cover what you don't want painted. Workbenches, etc. One roll will last you forever.
Kevin
  #24 (permalink)
Old 12-11-2007, 04:19 PM
tyman00's Avatar
Our booth for painting trailers has in-floor heating in it. That is the cat's meow. Plus when you are rolling around on a creeper and your shirt slides up you don't get a surprise when you slip of the creeper. Just warm concrete
In your shop, I wouldn't run the heater even if you were taking your air from the outside... just too scary. Seriously, I don't think you will have any problems if you turn your heater on 3-4 hours ahead of time. Your metal will be warm through and through and your air temp will be fine. It shouldn't cool off past 60 that quick. I am not sure what the proper range is for painting but maybe get your inside heat up to that point before you shoot. You might sweat at first but it will take longer to get to 60 degrees.
  #25 (permalink)
Old 12-16-2007, 08:21 AM
SuthnCustoms's Avatar
Crazy Ole Ironhead
Just a thought that a freind of mine in Pennsylvania did with his shop to use for painting off and on...
He found an old home that was being tore down and got the old water/radiator heating system out of it for free if he got it all out in a certian time.
He put 4 radiators in each corner of his shop and the heating unit outside in an isolated and insulated housing for it.
For ventilation and keeping warm while ventilating fresh air he put a trap door right behind one of them that goes directly outside and filtered for when he is painting and ventilating.
No hot glow or ignition whatsoever and ive been in the shop in near zero weather outside and was sweating in a T-shirt.
I know you dont have time or money to do it right now Dewey but ,I thought i'd share it with all here for future ideas for heating a paint booth area...John
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
no heater runn141 Engine 21 09-05-2006 06:07 PM
Heater has mysteriously stopped working. HotRodMan General Rodding Tech 8 12-29-2003 04:38 AM
Distributor Clock position (long) Screwy Lewy Engine 7 07-16-2003 01:25 AM
