Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Safe heater position for painting?
Old 11-20-2007, 09:55 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I think you heater should be close to the ground.
Heat rises.
Then you need a ceiling fan to circulate the heated & cold air
as far as painting in the dead cold .get it warm check it with a laser infrared thermometer & make sure that your intake air is pre heated.
do not leave any thing that can generate a spark on.
Those oil filled radiator heaters work real good at making radiant heat.
Do some experimenting before you go for the "money shot"
Good luck
Rob
"SlowRide66"
"Illegitimis non carborundum"
