Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Safe heater position for painting?
  #16 (permalink)
Old 11-21-2007, 05:35 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
[QUOTE=Rob Keller]I think you heater should be close to the ground.
Heat rises.
Your right Rob....heat rises....but fumes settle to the floor, thats why they recomend that any shop heater should be at least 18 inches above the floor. When I got out of the service I worked in a paint manufacturing facility. They had gas heaters like cboys mounted near the ceilings...the lights and light switches were explosion proof ( sealed air tight) . Any way those heaters ran while we were mixing solvents and resins making paint....never a problem. The way I do in my shop...I have infra red heaters....I warm things up good, turn off the heat , shoot the paint....wait awhile for the fumes to settle and then go back with the heat.
