Safest garage heating method
Hello Guys -
I'm enjoying summer but know winter will be here soon enough. I'm tired of not wrenching throughout the winter so I'm going to install a heater in my detached garage. I'm looking at a Reznor UDAS - which is a separated combustion unit (draws inlet air from outside the garage). The reason I'm looking at a separated combustion unit is this... Last winter I tried to put the Buick in our attached garage. That lasted one night because the next morning, the garage smelled so badly of gasoline. The Buick has a fuel cell and apparently the vent combined with that garage being so well sealed up really lets fumes build up. Remember no charcoal canister like new cars. The same issue happens when I temporarily store 5 gal gasoline containers = gas fumes build up. So is this really a venting/exhaust fan question since I will be insulating and sealing the "Buick's garage" up as well as possible. I want to avoid any dangerous situations. P.S. From my research, the safest option is a "Sealed combustion" heater, but I cannot find any of these. Speaking with Reznor , they no longer make Sealed units because they were difficult for maintenance. Thanks for the input, Ray |
Rayn,
Have you looked into a tube-type radiant heater? There are several manufacturers on the market. I have one in my shop and am very satisfied with it. Here's the brand I used: http://www.reverberray.com/products/ld.html You didn't say what type of fuel you want to use. Mine is a propane model with a 100 gallon tank in back of the shop. There are many threads on this site regarding shop heaters. Do a search and you'll find them. Hope this helps, Steve |
Check out a used mobile home heater. They're small, can be fit into a closet built outside the shop or in the attic, ducted into your shop from the installation point. No need to worry about a flash fire from the ignition. A lot of the newer homes are putting the units in the attic, saves on space and is easy to duct.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
As this is an extremely common topic, I've started a new wiki article on this subject: Garage heating. We already have a Building a new shop article, but we could use a separate article on the issue of heating.
Please help develop it. Thanks.
HomemadeTools.net -- Thousands of Homemade Tools |
garage heating
I have a Resnor overhead heater that I have mounted on a dolly with a flexible supply line. I have very large garage and I did not want to preheat the garage or even heat the entire garage. Obviously, the question of venting was considered.
Initially, I started by preheating the entire area and I intended to then let in fresh air and resort to localized electric heating. Preheating raises the temperature of the walls, equipment, cars so that a lower number of BTUs would be required. I installed a CO2 meter for obvious reasons but I found that it wasn't sounding any alarm ever. So I investigated. I talked with the local building department's heating people and they said that if the combustion is good there will be no CO2. So I bought a second CO2 meter to check the first and have been using an non-vented Resnor for years. I also have a partial basement under a 16x30 foot stall. by placing the Resnor in this basement, I can heat the ceiling, which is the concrete floor of the stall and I have radiant heat which is quite comfortable and which is a heat sink or bank that maintains a remarkable comfort level. Another thing you might consider is putting two inches of new concrete on your existing floor and lay down electric heating pads before the pour for a comfortable heating arrangement especially if you have no lift in your garage. |
| Recent Garage - Tools posts with photos |
| Garage Workshop | ckucia | Garage - Tools | 11 | 11-20-2008 06:42 AM |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| heating a garage while painting | Jsummers | Body - Exterior | 2 | 10-11-2006 03:05 PM |
| Heating your garage | 32chevy vett | Garage - Tools | 11 | 03-27-2006 05:36 PM |
| Heating a cinderblock garage | workingclass | Garage - Tools | 25 | 02-07-2006 09:58 PM |
