Safety Inspections - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 05:53 PM
chief36chevy's Avatar
Last journal entry: Hood holder/horn mount
Safety Inspections
Ok I could have sworn that I read somewhere that you could not run your battery cable along your fuel line. I thought it was NSRA but I canít find it. I donít intend to wire tie them together, I just want to run down the same frame channel. I plan to clamp them to the frame channel one at the top the other at the bottom.
Any thoughts?
Old 04-04-2013, 06:21 PM
vinniekq2's Avatar
pm techinspector1 he will help you
Old 04-04-2013, 06:33 PM
techinspector1's Avatar
Wiki Edits: 326
Any thoughts?
Yeah, you can run 'em together, you just can't run 'em in the driveshaft tunnel.
The Following User Says Thank You to techinspector1 For This Useful Post:
chief36chevy (04-04-2013)
Old 04-04-2013, 06:44 PM
thanks
I don't know why I thought that.
No problem the drive shaft is nowhere near the frame rail.
Chief
Old 04-04-2013, 06:55 PM
Wiki Edits: 326
Really?......
Old 04-06-2013, 06:28 AM
deadbodyman's Avatar
Wiki Edits: 11
legal or not why would you want to
If you put the battery in the trunk you do yourself a favor and run a ford type solinoid near the batt so that cable is NOT hot all the time,by running a solinoid it'll only be hot when you start it But even with a solinoid why take a chance ? just run the cable or the fuel line somewhere else ...what I did was run my cable inside the frame rail...A hot cable can burn through a fuel line in seconds.
Next time you beach about inspections at the track think about this. MARTINSR Hotrodders' Lounge 5 02-18-2011 07:03 PM
Initial Engine Inspections Rufus_2 Engine 1 06-05-2007 08:24 PM
Emissions & inspections in NC??? el pollo General Rodding Tech 5 07-23-2006 09:54 AM
NC State Vehicle Inspections Frisco General Rodding Tech 4 12-18-2004 07:52 PM
saftey inspections montea General Rodding Tech 1 09-21-2004 09:26 PM
