Safety switch question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-06-2005, 04:38 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
The safety switch in an OEM column is mechanical not electrical. There are two notches cut into a plate. If the shifter is not in one of these notches (park or neutral). The key won't turn.
The safety switch on a floor shifter is electrical. There are generally two. One for park and one for neutral. If one of the switches malfunctions. You can start the car in the other position.
I assume you have a button or a key on the dash. There should be a wire running from your start switch to the solenoid and another to the distributor. You cut into the wire running to the solenoid and put a switch on that line.
I would say any aftermarket column with a built in switch would be electrical. The solenoid wire would from the start switch then to the column and back to the solenoid.
  #17 (permalink)
Old 09-06-2005, 04:48 PM
rrmccabe's Avatar
GM Muscle
I have worked on hundreds of cars (literally) with electrical NS switches on the column. There are tons of them out there.
These mount on top of the column and has a tab that goes down in column. When the shifter sleeve rotates it moves the switch.
Back to the original topic. I would go for one of those francis kits someone mentioned.
  #18 (permalink)
Old 09-08-2005, 04:13 PM
Lokar offers one as well. We installed one on a 72 Chevy PU when puting in a 700R4. I am using Lokar on my Coupe and one supplied with a Geni Shifter in my PU. What ever you do, get one that works in neutral and park. It can be a pain to have to come to a complete stop and put the vehicle in park to start it.
Trees
  #19 (permalink)
Old 09-08-2005, 06:49 PM
bg's Avatar
bg bg is offline
I am looking at a LOKAR switch, but cannot get an answer about the bracket that comes with the switch. I need to know if the switch and bracket can be used with a transmission that already uses the "cable shift" that Lokar also makes. The bracket almost looks the same and mounts to same place on the bottom using the tranny bolts???
I guess i will try and order and cross my fingers....
Thanks
Bg
  #20 (permalink)
Old 09-14-2005, 07:20 AM
primerat's Avatar
New Member
Last journal entry: GAS PUMP
re: switch
I used a micro switch and made bracket on the trans pan and a tang on the trans shifter arm so it completes a circuit when your in park. B&M sell them for under $10.00 bucks Lokar is a lot more. Thanks AL
  #21 (permalink)
Old 09-20-2005, 03:43 AM
docvette's Avatar
Wiki Edits: 12
NS Switch
Doc here,
Look where your backup light switch is on the tranny, usually this is a SHARED switch on some model Transmissions.
Has 4 sets of contacts, 2 for backup lights, and 2 for neutral safety switch.
Not all have this, and I'm not totally sure on the R700, and I believe it is year dependent..
Best way to tell is crawl up under there and with an inspection light look for a plug ( sender ) coming out of the transmission somewhere close to the linkage arm with no wires going to it.
HOWEVER I did a Web search and most GM 70's to 80's.. A/T's STOCK<--READ) use a column combo switch that looks like this, and snaps into the lower column
So you may have to fabricate one if you don't have a spot to mount it with an arm extending from it.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #22 (permalink)
Old 10-04-2005, 12:20 AM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
BG, Search " Dakota Digital "Web page they make digital gauges for streetrods. I use them on all my cars, 6 now. The GSS100 is a potentiometer that mounts on any automatic>sends a signal to an easy to program neutral,back-up, shift indicator lights setup box. You can use any or one of the features. It costs right at 100.00. The IDIDIT needs the Dakota and thats what most rod buildres use. All these guys keep talkn early Chev but you said you have IDIDIT. The 700R4 tranny has no park switch on it. It was on the factory column. It doesn't matter cable shift or what? it connects to the trans lever with an i/8" aluminum rod. EASY to connect all of it.
  #23 (permalink)
Old 10-04-2005, 02:57 PM
bg's Avatar
bg bg is offline
Thanks for the info... I will look at the Dakota web site ...............
THANKS
Bg
  #24 (permalink)
Old 10-08-2005, 06:36 AM
New Member
how did you make out with your trans saftey switch?
I used the lokar set up .
I am running a GM 454 performance crate motor with a built 700r4.
Lokar has a set up that takes care of the neutral saftey switch and the back up lamps. Its a module that mounts onto the trans pan bolts and has a lever to connect it to the shifter pawl. its then wired into a relay pack you mount in the car/truck and you just run you solinode wire thru,from ignition swith to the relay pack then from the relay pack to the solinode. real simple to install.
the 700r4 also needs a torque converter lock up to work proper and a tv cable to control the kick down and transmition pressure. Did you get that figured out yet?
Let me know if I can help i just completed this on my car
  #25 (permalink)
Old 11-16-2005, 06:17 PM
New Member
Danchuk also provides a neutral safety switch similar to the Ron Frances switch.
safety switch street rodder 1937 Electrical 1 05-31-2005 08:04 AM
neutral safety switch jwash56 Electrical 2 05-24-2005 10:27 AM
Neutral Safety switch Hook-up 39chevy Electrical 2 07-18-2004 04:26 PM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 07:54 PM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
