Safety switch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 07:14 PM
bg's Avatar
bg bg is offline
I am at a stage in my truck project that i have installed most of all the essential parts needed to drive it and i do drive it . Now i am looking at installing a safety switch so the engine wont start in gear ??? Can somebody point me in the right direction to the hardware that i need...........
THANKS
Name:	IMG_0272 (Small) (2).JPG
ID:	6734   Click image for larger version
Name:	IMG_0285 (Large).JPG
ID:	6737   Click image for larger version
Name:	IMG_0281 (Large).JPG
Old 09-04-2005, 07:30 PM
bg's Avatar
bg bg is offline
I did a search and read where you splice in between the start igintion wire going to the solenoid to a switch somewhere on the column?? Do i have to buy this hardware that goes on the column ? I have IDIDIT steering column with a clump of wires coming out.
THANKS
Old 09-04-2005, 07:34 PM
rrmccabe's Avatar
GM Muscle
What do you have for a steering column and shifter? Usually the shifter or column has the switch in it.
Rich
Old 09-04-2005, 07:37 PM
bg's Avatar
bg bg is offline
IDIDIT steering column with shifter on the column and no key in column.
Bg
Old 09-04-2005, 07:43 PM
Automatic or standard transmission? If automatic most of them have the neutral safety start switch on the transmission it self and you just need to wire the switch in series with the wire to the S terminal on the solenoid. If it is a standard transmission the easiest way is put clutch safety switch in so it won't start until the clutch pedal is depressed.
Old 09-04-2005, 08:02 PM
rrmccabe's Avatar
GM Muscle
Actually, most automatics are in the column. Some floor shift autos are there. Do they offer that switch as an option ?
Old 09-04-2005, 08:05 PM
bg's Avatar
bg bg is offline
Its an automatic and i have no switch on the 700 tranny that i know of...
Bg
Old 09-04-2005, 08:13 PM
rrmccabe's Avatar
GM Muscle
Everywhere I looked online said NS switch is included with the columns.
Are you sure yours does not. Have a slot cut in the top of column for it?
Rich
Old 09-04-2005, 08:24 PM
bg's Avatar
bg bg is offline
I will check for the cut out slot tommorrow and see if it has one. I dont remember see it but could of overlooked it. I know for sure it has no switch on the outside of the column unless it is wired internal and included in the wiring harness plug. I can look at my column wiring diagram and see if its wired for the safety switch...
THANKS
Bg
Old 09-04-2005, 09:29 PM
I won't disagree with you, newer transmissions are in the column, I'm still in the 60's and seventies. Torque flights, C-4's and C-6' were on the trans. I didn't know what tranny he was running.
Old 09-04-2005, 09:31 PM
bg's Avatar
bg bg is offline
I have a Bowtie 700r transmission................
Bg
Old 09-05-2005, 10:47 AM
bg's Avatar
bg bg is offline
I looked on the column and no notch for a switch. I also looked at the IDIDIT diagram and no wire for a safety switch. I wonder if the Bowtie tranny will have any kind of switch built in for park safety switch.???
Bg
Old 09-05-2005, 11:43 AM
rrmccabe's Avatar
GM Muscle
I looked at their site and looks like some have it and some dont.
I dont know about the particular transmission but I doubt it. Hope someone with experience with that trans will chime in.
There are ways to do it. I MUCH PREFER factory "safety switches" but you can mount a switch off a couple pan bolts that is closed when the shift arm on the trans is in the fully park position.
You with think that column manufacture would make that stock on all.
Rich
Old 09-05-2005, 12:34 PM
Ron Francis.............the wiring harness guy......has a neutral start switch for you transmission.
It mounts on the transmission.........( and looks a lot better than a bunch of wires on the column )
http://www.parts123.com/parts123/yb....Q24168217736b~
Just click on the above link for a photo and then clink on the photo to enlarge it.....
General Motors made some neutral start switches like these for the Turbo 400's in early vans.........and I run one in a roadster. Works great........and looks good too...especially in a roadster where you can see all of the steering column...
Old 09-06-2005, 04:14 PM
jpelli's Avatar
Ron Frances wire makes a good electric neutral safety switch easy to install and works great. You can go to their web site for more information.
safety switch street rodder 1937 Electrical 1 05-31-2005 08:04 AM
neutral safety switch jwash56 Electrical 2 05-24-2005 10:27 AM
Neutral Safety switch Hook-up 39chevy Electrical 2 07-18-2004 04:26 PM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 07:54 PM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
