Sag in last coat of pearl - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 12:16 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Hey Bee4me, I sent you a pm regarding this, and called you Vince by mistake...sorry.. lots of names to remember, anyway I stumbled when making my last pass of pearl on this car an shot a real heavy spot that sagged on the drivers quarter. I am using HOK SG-100 intercoat to apply the pearl. I also added a little retarder for humidity reasons, and to let the last coat flow out real nice. It has been an hour now at post of this thread. In an hour or so can I lightly sand that area with maybe 1000# and just throw on some dust coats and then clear the whole thing? I am trying not to have any variations in the pearl. There is only a 12 hour window on the topcaoating the sg-100, and I don't want to apply any more "color" to the car. Do you all think this will work fine?
BK
Old 05-12-2005, 12:46 PM
New Member
not sure how big the run is, but I have had the same thing happen to me once on a pearl job and I did as you have suggested and everything worked well.
I was extremly carefull when sanding the run, as I only removed material from the run itself then feathered as light as possiable around it.
Then I put a couple very light coats of pearl over it and blended a couple feet away into the rest of the panel.
worked for me, but I just a part timer so maybe someone else has a better way.
once you clear it well be much harder to blend so I would try and see before time runs out.
good luck Dave
Old 05-12-2005, 01:27 PM
BondoKing's Avatar
KING OF BONDO
Since we are both on the same page, that is what I have done. It sanded out fine, and looked good other than there was a color difference, but when I dusted on the base you could see where the sag had been again. I am going to try and sand it again in a half hour to 1 hour. I dont want to clear this thing in the dark. Maybe I should sand a little more this time?? I tried to sand as lightly as I could, when I could not see it anymore I stopped.
BK
Old 05-12-2005, 09:13 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Yes I got it Fred. Just teasing you Matt.
Hey NO big deal,People call me ALOT worse someday's.
Sag's are a MAJOR PIA to get rid of and it MAY take some razor blade scraping and sanding to get rid of it. It and the area around it will HAVE to be flat or it will come back on ya.
I sagged the hood scoop on the 69 I did right at the hood/scoop line on the back CORNER. UGGGHHHH!!!! The hose got hung up right as I was coming off the cowel and up the scoop back and I "thought" I lucked out till I came back in for the second coat and a small puddle had formed.
I don't know what your color scheme is or how heavy a pearl mix your using.
Old 05-12-2005, 09:55 PM
BondoKing's Avatar
KING OF BONDO
Pia
A puddle... that is terrible, worse than what i had. I used the whitest white you could get... pure white base with drying agents only added PPG Omni, next was PPG pearl prisim blue, put on with HOK SG-100 intercoat, smoothered in two freakin heavy layers of bugs,solvent pops and bug guts ( I squashed a few trying to get them out).. or someone else may say Sikkens Auotclear. The sag was forgiving, I am hoping the solvent pops will be too.
I may have to start laying on a light first coat after tonight.
BK
Old 05-13-2005, 11:25 PM
BK
Next time (hopefully never!) this happens and you need to sand something, try using the sg100 (with no pearl or additves) as a "sealer" coat to see what might happen. If the sag spot shows up you can sand the sg100 with out interfering with the pearl.
Old 05-14-2005, 03:33 PM
Have Gun, Will Paint
and remember for next time.......when using intercoat clear, you don't want to "flow" it.......just make medium passes with it.
The only thing that you should "flow" is the topcoat clear.
Arrrgg! Clear coat flaking off!! dpowers Body - Exterior 16 04-01-2008 11:10 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Whats The Deal With Silver Paint??? 41chev Body - Exterior 24 10-20-2003 01:24 PM
pearl's in paint 2wld4u Body - Exterior 8 10-18-2003 08:26 AM
Can I Spray Clear Coat Over Clear Coat ??? STATUTORY GRAPE Body - Exterior 2 10-07-2003 09:09 AM
