Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - saginaw 3 spd overdrive/standard differences???
Old 07-25-2006, 01:30 AM
jimfulco jimfulco is offline
Are you trying to get better gas mileage or better acceleration? Overdrive helps gas mileage but it won't do anything for acceleration. On the other hand, a typical (Saginaw, Muncie, BW) car-type four-speed trans will add a gear in that big gap between your current 2nd and 3rd gears, and most of the above will bolt in where your 3-speed is with little modification.
