Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - saginaw 3 spd overdrive/standard differences???
Old 07-25-2006, 02:32 PM
cabowabo's Avatar
cabowabo cabowabo is offline
big Q
yes it bolts in
remove the tranny this would be good to put in a new clutch and resurface the flywheel and pilot bearing then if you unbolt the 4 bolts to the bellhousing and swap the 4 spd in and reassmble and adjust clutch you need floor shifter for 4 spd of course
i changed mine in 2 hrs but i had already had the brand new clutch in 11in.
