We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-01-2006, 02:17 PM
paulo 1 paulo 1 is offline
saginaw 4 spd embarrassement
Well,it happened to me.Our fully restored '74 Camaro is being test driven to debug the usual stuff.This saturday I was going up a narrow street on the out skirts of Rio de Janeiro when I decided to turn around and return.Back and forth a few times and suddenly when I began to let go the clutch pedal the car did not move but the RPM went down! Guess what? Tranny engaged in 2 gears at once! Unreal! The worse,we were fully blocking the street on a steep hill,output shaft stuck!Car would not move even when clutched...
Ran 2 miles to the shop,grabbed small floor jack and tools,ran back to the scene,raise,struggle,curse and with the help of all mighty God,I got it unstuck.
Upon inspection of the inner side cover shifter mechanism,I realized that it can actually be engaged into first before reverse is fully desengaged!
The stock shifter had been adjusted with the centering pin and care.You guys know of any remedy?
Old 10-01-2006, 03:11 PM
matt167 matt167 is offline
matt167's barnstar
Wiki editor
Last wiki edit: Finding vacuum leaks
Wiki Edits: 31
normally rocking a car back and forth gets it unstuck
Old 10-01-2006, 03:41 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
Check for worn shifter mechanism..some times those pins get worn and allow that to happen..The remedy seems to be replace the shfter pins and rebush the shifter so it is tight with no slop..
Sorry bout your difficulty..
Sam
I would rather make it work than make it popular..And if it does not work it will not be popular..
Old 10-02-2006, 01:36 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Ummmm, I've done that.
Don't feel too bad.
Old 10-02-2006, 10:55 PM
jimfulco jimfulco is offline
Same here.
It helps to pull straight back on the shifter, maybe even with a little leftward pressure, when shifting out of reverse. This ensures that reverse is fully disengaged before the shifter moves into the 1-2 position.
Old 10-03-2006, 07:01 PM
OK guys.Thanks for all the suggestions.We are considering a new Hurst shifter assembly even though I understand there is a design flaw inside the cover,allowing it to happen.I imagine there was a TSB back
then,though.It should have put people into really embarrassing situations.If the new shifter does not solve it,I will extend the reverse curvy-slotted piece inside the cover.That will do it once and for all.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "saginaw 4 spd embarrassement"
saginaw 3 spd overdrive/standard differences??? neebl Transmission - Rearend 6 07-26-2006 02:41 PM
saginaw 4 spd overdrive scatsihc Transmission - Rearend 0 02-05-2006 07:44 PM
4 spd Transmissions TeamHagnNag Transmission - Rearend 2 02-01-2005 12:40 AM
TH350 vs Saginaw 3 speed ? bowtieorbust Transmission - Rearend 4 01-20-2004 07:16 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
