saginaw 4 spd overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 07:44 PM
I was reading the article where a sag overdrive unit from a 65 and later was fitted to a saginaw 4 spd. the overdrive in my 59 chev is a borg warner. i have seen other articles of this conversion. Are the overdrive units the same units or did saginaw and borg warner both make overdrive cases? will they interchange?
Saginaw 4speed overdrive conversion (pics included) Shefron Transmission - Rearend 23 01-31-2006 10:52 PM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
question on converting saginaw 4 speed to overdrive??? shadetreemechanic Transmission - Rearend 5 02-27-2004 02:29 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 09:25 PM
