As long as you don't shock it too much, it might last you a while. Some Saginaws can handle more torque than others. One with a higher-ratio first gear will not handle as much as one with a lower ratio. See if your input shaft has any shallow annular grooves cut around the splined portion. If so, count them and look at http://www.dandltransmission.com/saginaw.html to find what your ratio is.
saginaw is a weak gear box, not ment for performance application's, Migh last for a few 7000 rpm shift, but it will let go, just a mater of time. Look for a muncie thats the transmission G.M used in its high performance cars.
| Saginaw 4 speed help | 67camarokid | Transmission - Rearend | 4 | 11-24-2005 08:48 PM |
| 292 with saginaw 4 speed? | widunn | Transmission - Rearend | 1 | 10-09-2005 11:29 AM |
| question on converting saginaw 4 speed to overdrive??? | shadetreemechanic | Transmission - Rearend | 5 | 02-27-2004 02:29 PM |
| TH350 vs Saginaw 3 speed ? | bowtieorbust | Transmission - Rearend | 4 | 01-20-2004 07:16 PM |
| saginaw 3 speed od conversion | slingslingbinks | Transmission - Rearend | 4 | 10-06-2003 01:07 PM |
