Saginaw 4 speed shifter questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2010, 09:59 PM
Heres the deal i've got a 69 camaro 4 speed saginaw, 67/68 Hurst Competition Plus shifter......want toknow if I can make this work..what linkage or mounting plate to use? Not going with a console so thats not a problem
Old 03-04-2010, 11:11 PM
ericnova72's Avatar
More for Less Racer
Yes you can use the Comp Plus shifter, you just need the Saginaw linkage kit from Hurst. The mounting plate for the shifter is typically the same as the Muncie . Linkage rods and shift arms are different, especially the reverse gear link and arm for the Saginaw.
3 speed saginaw or muncie? hotrodder777 Transmission - Rearend 1 11-17-2009 06:10 PM
Saginaw 4 speed Questions troyhoot Transmission - Rearend 6 06-10-2008 12:20 AM
292 with saginaw 4 speed? widunn Transmission - Rearend 1 10-09-2005 12:29 PM
Richmond 5 speed, 56 Chevy and shifter 56classic Transmission - Rearend 3 08-28-2005 09:00 PM
49 3 speed questions fastback49 Transmission - Rearend 3 06-03-2005 07:36 AM
