Saginaw 4 speed transmission - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-07-2014, 04:38 PM
I found the stock WC T5's to be actually weaker than the NWC unless the HD support plate for the WC's tapered bearings was in place. Lower ratio boxes usually stripped the teeth on the input shaft or 3rd gear, V8 boxes usually failed at 3rd gear.
Did not include aftermarket gearsets though.
  #17 (permalink)
Old 05-10-2014, 01:32 AM
junior stocker's Avatar
The 3.11 and 3.50 first gear Sags were originally used in the Monza and Vega cars. As such, they are lighter weight internally; the gears are actually narrower. Keep up the hunt for a different 4-speed, a Muncie or B/W, and sell the Saginaw before your turn it into a pile of broken parts, and it's no longer sellable. Butch/junior stocker.
4 Speed Saginaw TwoFace69 Transmission - Rearend 3 11-10-2009 06:32 PM
Saginaw 4 speed borows72camaro Transmission - Rearend 1 07-24-2009 05:53 PM
saginaw 4 speed can it be done? 301nova Transmission - Rearend 15 05-13-2008 02:02 PM
Saginaw 4 speed rockabilly66 Transmission - Rearend 5 04-18-2007 07:44 PM
4-Speed Saginaw Transmission rebuild Shefron Transmission - Rearend 2 01-16-2003 11:15 AM
