Saginaw 4speed overdrive conversion (pics included) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-09-2005, 10:40 PM
Glenn: Yes I would like a digital copy.Backintime3334@aol.com
Originally Posted by Hippie
Tom, You have mail.
Glenn aka "Hippie"
Gary? Want a digital copy? It's a pretty decent scan, fairly high re solution.............. I'd be happy to send it to you.
Glenn: Yes I would like a digital copy or any thing else on this conversion. Thanks Gary send to backintime3334@aol.com
  #17 (permalink)
Old 09-09-2005, 10:58 PM
Originally Posted by Old School Nut
well I looked last night. the article I have starts on page.30 of Hot rod's April 1975 issue. if their is another article done in 1974 I would sure like to see it!
Waukesha, well your not to far from me then, I go to a swap meet up their... BTW if you are still looking for the trans, good luck, they are getting very hard to find. Their is one guy tho I see at the Jefferson swap that has one but he wants a lot for it, but it already has the conversion done....
-Leo-
Leo:Thanks for the Hot Rod Year and month. I will have to research if there is another article from 74. I am going to the Jefferson swap meet. Can you let me know what area this fellow with the trans is in so I can check it out? E-mail me at backintime3334@aol.com Thanks Gary
  #18 (permalink)
Old 09-10-2005, 11:16 AM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
hey Gary, check your private messages..
-Leo-
  #19 (permalink)
Old 10-08-2005, 08:27 PM
If you'd still like the copy of the Hot Rod article I can e-mail it to you. Might take awhile to download though if you have dial up. It's not that long, but mine includes the illustrations so the PDF file is kind of large.
OK not as big as I remembered, only 803KB.
I'm interested in any information and photos of the Saginaw 4 speed overdrive conversion.
reapperson@aol.com
Thanks
  #20 (permalink)
Old 10-08-2005, 09:39 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I've been watching this one very closely, as I am looking for a manual OD trans for the Malibu. I thought I was only looking for a New Process 440, now I will have to expand my search.
And if there are pics that you put on another site, put the URL in here and I will link to it in the Transmission information sticky thread.
Unless you want a whole writeup done in here, we might be able to accomodate that.
  #21 (permalink)
Old 10-11-2005, 12:23 AM
will the OD work on a muncie 4 spd ???
  #22 (permalink)
Old 10-11-2005, 08:19 PM
No. It's just a Saginaw OD unit adapted from a Sag 3-speed to a Sag 4-speed.
  #23 (permalink)
Old 01-31-2006, 01:15 AM
hey...
I have a saginaw 4 speed that i just aquired. No rings on the input. The mainshaft bearing is shot so a rebuild is in order. Tell me this, I breifly read the article and if I understand it right your supposed to take a 3 speed tailhousing and put it to a 4 speed? I have 2- 3 speeds on the floor but I have no clue what the ratios are and if they are any good. What numbers am I looking for? What other numbers on the Saginaw would help me to identify the year and ratios or is the rings on the input the answer. No rings-2.84 first right?
  #24 (permalink)
Old 01-31-2006, 10:52 PM
Saginaw ratio ID & parts can be found at http://www.dandltransmission.com/saginaw.html
