Saginaw 4speed Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2006, 11:41 PM
I have heard that you can tell what gear sets are in the trans by counting the number of grooves. Where are these grooves? Are they the grooves on the input shaft spline.
Erick
Old 11-03-2006, 05:15 AM
RippinRon's Avatar
Yes the grooves are on the input shaft.
Old 11-03-2006, 05:33 AM
On the pilot shaft. 4ring- 3 ring- 2 ring, all 4the gears are the same. The 4 ring I have has a 1st gear is soooooo low you can use it for only about 10 ft!
Old 11-06-2006, 07:31 PM
saginaw grooves number/
my spline has three grooves and then a space then another
Old 11-06-2006, 09:58 PM
powerrodsmike's Avatar
Wiki Edits: 161
Found in the knowledge base:
http://www.dandltransmission.com/saginaw.html
scroll down to the bottom of the page and there is a list of saginaw trans ratios and groove counts.
I'd call it 3 grooves and a wide ratio trans.
mikey
BE different....ACT normal.
Old 11-06-2006, 10:34 PM
thanks for the info
Old 11-07-2006, 05:08 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
powerrodsmike probably got that out of the Knowledge Base from one of my many contributions over the years I've been on here, I used to have all that stuff at the top of the Trans - Rear Forum in a couple of sticky threads.
All of that information was a lot to post into a couple threads, and eventually was added to the KB.
I PM'ed a link to a picture on the internet confirming the three groove input shaft to razdude, I just didn't take the time to confirm the gear ratios for him.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
