saginaw cluster tooth count
I have a NOS cluster gear that can't ID. I believe it is a saginaw 4 speed but i can't find a chart anywhere. Any help would great
Thanks |
Saginaw 4 speeds had 3 or 4 different first gear ratios... counting teeth may be difficult to match up.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks for the replies. There is no numbers on it. I have the original box too and the part number has faded to nothing.
| Ring & Pinion Tooth Contact Pattern GM 10-Bolt | leejoy | Transmission - Rearend | 52 | 12-15-2006 06:26 PM |
| Help with Saginaw trans ID | Will_H#24 | Transmission - Rearend | 2 | 04-16-2005 05:38 AM |
| should Lounge posts count towards post total? | Jon | Hotrodders' Lounge | 107 | 10-20-2004 07:42 PM |
| Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro | GMC72NV | Transmission - Rearend | 0 | 11-10-2003 02:51 PM |
| Speedo gear tooth count on a Muncie? | zachscc | Transmission - Rearend | 3 | 01-23-2003 06:10 PM |
