saginaw id help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2013, 03:39 PM
saginaw id help
tail...A 45......3855722
case has GM 9854726 A 45
cover...3849534...6GM....
GM 14 stamped on case also....How to tell what car/truck it will fit? thanks for any help...old chevies never die ,,they just go faster...
Old 08-27-2013, 04:54 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Do you have a 3 speed or a 4 speed? The 3 speed will have 2 shifter shafts, the 4 speed will have 3 shafts.
This may help some:
KellyGeneral Information
Saginaw transmissions come in two basic varieties, 3-speed and 4-speed, and have the following characteristics:
  • Cast iron case
  • Cast iron side cover
    • 7 attaching bolts
    • Shift levers
      • 2 for 3-speed transmissions
      • 3 for 4-speed transmissions
  • Cast iron tail housing
Saginaw 4-speed Gear Ratios No grooves 2.84 2.01 1.34 1.00/ 1 groove 2.54 1.80 1.44 1.00 Common/1 groove 2.54 1.80 1.32 1.00 Rare/ 2 grooves 3.11 2.20 1.47 1.00/ 3 grooves 3.50 2.46 1.65 1.00 The grooves are on the input shaft.
Kelly
Old 08-27-2013, 05:08 PM
Also to the best of my knowledge there are really no identiying marks other than part numbers that would indicate a year range it was used in. The rings on the input shaft are used to identify the gear ratio that is inside (unless it has been swapped out over the years). It should fit any GM with the same input shaft, the out put shaft could be matched to a yoke and the universal would adapt that to your driveshaft. I'm sure someone knows more about them than I do, so hopefully someone more knowledgable will jump in soon.
Kelly
Old 08-27-2013, 08:27 PM
douglashwy's Avatar
There should be a small flat little like ledge at bottom of trans believe on shifter side stamped like R4*** something like that it will give you date code but other than that I don't think you'll be able to link it to what car it came from.
saginaw
saginaw steve58 Introduce Yourself 2 05-02-2010 09:00 PM
saginaw? mista-nova Transmission - Rearend 2 02-27-2007 12:54 AM
Another saginaw ? bowtieorbust Transmission - Rearend 1 06-27-2004 04:22 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
Old Saginaw MI2600 Transmission - Rearend 0 08-17-2002 07:40 AM
