Saginaw Manual Steering Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2006, 09:57 AM
Does anyone know what type of oil (lube) is used in the saginaw 525 manual steering box
Old 08-19-2006, 10:11 AM
powerrodsmike's Avatar
Wiki Edits: 161
Wheel bearing grease. pack it full, but leave room for the bearing housing on top.
That is what the guy at mullins told me when I had to clean out the 90 wt that someone had put in one of their vega boxes.
Don't use 90 wt gear oil. It will eventually drain out of the box.
The factory manuals call out a GM lube number that is no longer available, and has not been superseded. I called around and did a search for the stuff a few months back
Hope this helps, mikey
BE different....ACT normal.
Old 08-19-2006, 11:10 PM
Wonder if this Ford stuff would work, if it's available.
http://www.hammar.dyndns.org/ROTUNDA/19578a.jpg
Old 08-20-2006, 12:42 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I have used just plain old valvoline grease gun tube.
I think the last one I did I used Mobil 1 synthetic grease.
http://www.snopes.com/politics/soapbox/lamm.asp
Repair a leaky steering box gator412 Suspension - Brakes - Steering 8 06-01-2008 02:03 AM
69 Nova - manual steering box slack stratt134 Suspension - Brakes - Steering 4 08-16-2006 12:26 PM
Ford Ranger manual steering box ? AC/DC Suspension - Brakes - Steering 12 08-12-2006 06:41 AM
What are the 3 adjusters on my steering box? oldguy829 Suspension - Brakes - Steering 1 06-25-2006 02:06 PM
steering box swap sbhoney Suspension - Brakes - Steering 0 04-13-2004 05:50 PM
