Saginaw Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2008, 08:22 AM
Saginaw Problem
I've Got A 4 Speed Sginaw And I Think It Is Stuck In Reverse. I Am Unable To Move The Reverse Linkage. I Was Wondering If I Will Be Able To Take The Side Cover Off Of The Transmiision And Sucessfully Get Everything Back Together With It In The Car. Wasn't Sure If It Needs To Be On Its Side In Order To Get The Shift Forks And Such Back Into Place. I'm Thinking I'll Probably Have To Remove The Tranny. Is There Any Special Trick To Getting It Back In Easily. I Want To Leave The Bellhousing On The Engine And It Seems Like I Never Have Any Luck Getting The Tranny In That Way. I Always Have To Bolt The Bellhousing To The Tranny And Then To The Engine.
I Just Want To Make This Tranny Work For Now Until A Real One Comes Along.
Old 08-29-2008, 05:19 AM
3rdmember
well, i've cleaned the teeth off of more muncies than saginaws so as far as a "real" transmission,well, lenco makes one
anyway,see if you can move the 1-2 and 3-4 levers in to a neutral position and then try the reverse.
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
