Saginaw PS pump rebuild shaft bushing replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 08:29 PM
I'm rebuilding a power steering pump. Got the o-rings and a new shaft bushing. I have access to a press at work, but do I press it in from the front or the back, doesn't matter? I'm probably in over my head here this time. Any tips guys? I don't want to screw this up
Mustang Ps Unit Using Lt1 Pump dchatcher Suspension - Brakes - Steering 6 02-27-2010 02:43 PM
Excess oil pump shaft clearance HP52TA Engine 2 03-15-2009 09:54 AM
oil pump shaft for a 400 chevy kunkle Engine 5 02-06-2009 08:06 AM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 08:50 PM
C6 tail shaft bushing removal cboy Transmission - Rearend 11 08-07-2005 06:46 PM
