Is a Saginaw pump compatible with... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2008, 07:59 AM
Will a Saginaw pump mount up on a 72 sbc if either change the block to a serpentine configuration or change the pulley on the pump to a v-belt style pulley? Rebuilding an 88 chevy truck with a 72 350 and was wondering if I could use the saginaw pump that came in the 88(without alot of fab work) cause it is still in good shape.
Thanks,
Alan
Old 02-16-2008, 09:31 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
You can use a v-belt pulley on the 88 pump but it has to be for the press on style pulley. I do not know if it will line up as your 72 should have the short water pump and the 88 is the long style. The pressure outlet on the back will have to be used from the 72 so your hoses will work.
Old 02-16-2008, 09:33 AM
Would it be simpler to use a pump for the 72? How will that affect the stock steering box on the 88? Thanks for the great info by the way.
Alan
changed fuel pump from mech to elec - HELP! junkyard junkie Engine 16 09-19-2007 08:30 PM
smaller fuel pump body needed chevy mikee Engine 7 08-28-2007 02:23 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 07:38 PM
93 dodge shadow fuel pump repair junkie Electrical 2 10-02-2003 09:05 AM
