Saginaw Shifter Handle removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2012, 06:48 AM
BT74's Avatar
Went to put a fresh clutch in my 1980 El Camino with the stock saginaw trans (4 speed). Cannot figure out how to remove the shifter handle so I can slide the trans back out of the bellhousing. Never had a ride with a saginaw, always muncies or BWs, and ALL of those I've owned had Hurst Comp+ shifters that the handle just unbolts from.
Old 05-28-2012, 11:08 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Should be just about like the muncie trans IMHO Just unhook the linkage from the trans and then un-bolt the mechanism from the tail-shaft. should be just fine. JMO
Cole
Hood handle removal vanislander General Rodding Tech 0 05-16-2010 11:49 PM
Saginaw 4 speed shifter questions. PairOf69's Transmission - Rearend 1 03-04-2010 10:11 PM
shifter for saginaw 4 speed trans GMR Transmission - Rearend 6 02-21-2010 08:15 AM
saginaw trans in 76 vette/what shifter to use steve007 Transmission - Rearend 2 03-15-2008 07:02 PM
B&M Shifter Handle Jag Daddy Interior 2 09-17-2003 09:17 PM
