Saginaw to a small block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2002, 08:33 PM
The Vandal's Avatar
Engine Tech Addict
Post Saginaw to a small block?
1970 Chevelle - currently has 250 six with Saginaw 3-speed. Will a small block bolt up? What changes will I have to deal with? Thanks
Big Mike via The Vandal
Old 02-10-2002, 06:52 PM
New Member
Post
a small block will almost install itself
i'm not sure (hope one of the guys here knows) but i belive you will have to change the frame mounts on the chassis
you will prob need a new wider v8 radiator, a new flywheel if you intend on keeping the saginaw, and new accesory brackets
