I AM A TROLL, HENCE YOU SHOULD IGNORE ME.
[color=red]!@#$%^&*()[/color][color=orange]`~[;.,<>?":{}[color=yellow]/*-.+=-[/color][/color][color=green]pqlamzbfhgt [/color]
[color=blue]Reason for edit: This user is a known TROLL and has proven himself in not being a useful member of this bulletin board. His language has gone well outside the marginal borderline for conduct on this board, and many of his posts make their way to moderator deletion or transfer to the Dump.[/color] Last edited by M&M CUSTOM; 12-27-2003 at 09:52 AM. |
If either of you interested in installing can post the bolt pattern measurements I will be out in the shop later today and do the same with the T-5 transmission I have.
Unless I find it on the internet, it might be in the transmission information post at the top of the trans/rearend forum, if it isn't and I find it I will post it in the trans info for future reference. [color=yellow]The only information I found in 2 hours of searching the net, is the main input shaft hole in the bellhousings in the earlier Chevy's is smaller than anything made after somewhere around 1970. And that the Lakewood bellhousings list (for most chevy bellhousings) the application as Muncie, Saginaw, AND the BW T-10.[/color] I will check later to see if the bolt pattern on my T-5 is the same as a Muncie/Saginaw bellhousing I have in the shop.
I'm actually making progress on my 1988 Suburban TH-700R4 to SM-465 transmission swap, CLICK HERE TO CHECK IT OUT. CanAm Chevelle Club 700R4 Basics 700R4 Basics W/pics ______ Last edited by M&M CUSTOM; 12-27-2003 at 05:46 PM. |
