Saginaw Transmission Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 01:20 PM
I recently purchased a rebuilt Saginaw four speed tranny. For some reason, I have tranny fluid dripping onto my floor apparently coming from the connection between the speedometer cable and the speedometer. The only reason I can think of is the lack of a vent in this tranny, which I discovered. If that is the case, what can I do short of changing tail shafts with one that has a vent? Has anybody had this problem or know a solution?
Old 08-30-2006, 02:32 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I drilled a 3/32 hole in th top of mine.
Old 08-30-2006, 03:19 PM
rj57's Avatar
If you have gear lube leaking from where the speedometer drive gear slides into the transmission, then the drive gear must be worn. They spin at quite a few revolutions during the time you use the transmission.
And there's also a rubber O-ring that goes around the slip in collar for the speedo drive gear. If your transmission is missing this O-ring you will get gear lube leaking out of there.
Old 08-30-2006, 09:34 PM
saginaw tranny problem reply
Thanks for the answer; but not leaking at the tranny, but under the dash board at the speedometer.
Old 08-30-2006, 11:29 PM
There's also a seal in the outer end of the "bullet" where the driven gear comes out to meet the cable end. I will confess to having had the problem with a Saginaw 3-speed many years ago, but I don't remember actually fixing it, except that when I swapped it for a Muncie 4-speed, it didn't do it any more.
blower idle rpm problem Ratoflic Engine 7 12-01-2008 04:31 AM
350 transmission reinstall front pump problem.... BigDawgsEatFirst Introduce Yourself 3 08-28-2004 01:03 PM
can a leak on the intake manifold cause problem when my transmission shifts dopey Transmission - Rearend 7 08-01-2004 10:43 AM
transmission problem turbo 350 jester429 Transmission - Rearend 1 10-04-2003 08:34 PM
transmission problem smallz Transmission - Rearend 5 05-31-2003 11:47 AM
