sagniaw tranny gearing..is it good or bad - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 11:29 PM
i have a 4 speed saginaw out of a 76 nova, which is 3.11 2.20 1.47 1.00 for the gearing. the rearend i have has 2.79 gears in it, the car is a model a with a big block. wiill this setup make me rev high on the highways with lower speed or rev low? is the 1st gear good for off the line, not interested in racing, just response.
thx
Old 04-14-2006, 08:44 AM
MI2600's Avatar
Member# 3287
You should be good on the highway with a 1:1 final trans gear and the 2.79. Your first gear will wind up really quickly. Those gears weren't meant for V8s, but they'll work if that's all you have.
Old 04-14-2006, 08:50 PM
I have the same trans in a '72 Nova w/350, 3.08's, & 25.5" tires, and I like it a lot. If your current trans is a typical 3- or 4-speed stick, high gear will be the same in both (1:1), so highway revs will be the same. The 3.11 low gear definitely helps from a dead stop, compared to the more common 2.5 low.
Car cover good idea or bad? oldred Body - Exterior 26 05-02-2013 08:25 PM
vortec fuel regulator bad or good? g.b. Engine 11 01-02-2006 09:55 AM
RUSTBUSTERS....Good or Bad?? 40 Body - Exterior 4 01-01-2003 12:11 AM
good news! it's a boy!, Bad news, an ugly messy cesearian! bullheimer Engine 13 08-15-2002 09:16 AM
