salee zz383 500 - thoughts.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2013, 12:30 PM
http://www.sallee-chevrolet.com/Chev...8s/383-500.cfm
what do you guys think of this combination. one of my buddies at work has this zz383 short block.
he wants to mimic this heads & cam combination.
AFR 195 Street elim (65cc milled down to 58cc) as per sallee spec. 10.1:1 comp
P/N 2204, Edelbrock Hyd. Roller, Lift (.539 I, .548 E), Duration @ .050 (234 I, 238 E)
is this combo still relevant? Its from 5-8 years ago, any comments/suggestions???
Old 01-04-2013, 12:48 PM
vinniekq2's Avatar
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
383 with 500 hp using 195 AFR heads and a roller cam is a good combination. what parts are you using for your combination?
Old 01-04-2013, 01:43 PM
vinniekq2's Avatar
AFR 195s flow about 20 cfm more and much better on the exhaust side
Old 01-04-2013, 03:26 PM
Banned
Originally Posted by hcompton View Post
Ok i got ya. It says a speacial pair of afr 195 heads which means no longer 195s but ported out for more flow. Take note of the 500hp at 5700 rpm. Thats an engine that will need a 4000 rpm stall converter. Tq peak at 4600 is also pretty high. Hotrod mag has the same build they go into detail. Just google
Is this the motor you were talking about.
Chevrolet Performance Parts
Here is the link to hot rod mags build.
Chevy 383 Engine - We Build a Small-Block That Makes 500HP and 500 LB-FT - Hot Rod Magazine
Yes this looks like it can be done. I do not think this will be much of a street motor. But certainly fun to drive.
500hp at 5700rpm is ridiculously LOW for a sbc. a 4-5,000 stall would be needed for racing but on the street a 2000-2500 should be more than adequate.
ZZ383 timing fivewindowcoupe Engine 5 09-01-2010 07:49 PM
ZZ383 knocking fivewindowcoupe Engine 17 03-20-2010 01:27 PM
zz383 425hp chevy streetrodderbn Engine 1 09-12-2007 05:52 PM
Zz383 Don Meyer Engine 3 05-09-2007 08:57 PM
please help timing a ZZ383 mcgrsr Engine 9 01-21-2005 11:12 AM
