Saltwater eats Metal... What eats Rust ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2003, 11:34 AM
grimmey slimey lowrider
I am getting ready to strip all the paint off my T- Bird before the body work portion of the project goes into full swing.
I have some rust issues.
I have a sand blaster.
I have a welder ( my pops) yyaaayy !
I have a day off.
once I use aircraft stripper and remove the paint from some areas that are pitted and nasty with rust, if it is bad enough, I will cut it out and patch a new piece in.
On the otherhand, if I can keep the pannels original I would like to.
What products can I use to seal over any rusted areas, and then use body filler or door glass on to build it back up and are able to bond and be painted over ?
RUST MORT was a product a buddy mentioned.
He said it would create a bond with the rust and make a resin plastic seal with it, and could be painted, or bondo-ed over.
There is only so far I can grind rust before it starts to cause issues with major surface blemishes in un important areas that I simply want to seal. In some areas I simply cant get at it with any tools and not work majorly in that area on due to the lack of necessity at present time. I need to get the car to look decent again (body wise).
Thanks !
Old 07-01-2003, 03:59 PM
USA1's Avatar
Look for a product called por-15. I think it's just what you need.
Old 07-01-2003, 09:07 PM
Sandflea427SS's Avatar
Anything with a throttle
A very healthy checkbook!!!!
Old 07-02-2003, 11:27 AM
S10 Super Sleepers
Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15 Por-15
Old 07-02-2003, 12:56 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Thumbs up
And just in case you missed that......POR-15.
Old 07-02-2003, 12:57 PM
S10 Super Sleepers
Old 07-02-2003, 01:34 PM
levis classic's Avatar
New Member
POR-15 is the cats a##. It works wonders!
Old 07-02-2003, 04:44 PM
Seon's Avatar
Trixie...oh no I miss read it, it's Rust not Russ. :skeptic:
Old 07-02-2003, 06:56 PM
adtkart@aol.com
Scott.... you've got me really confused. What is it you are trying to say?
Old 07-06-2003, 12:17 PM
Rubberman2003's Avatar
POR-15....also 80 grit sandpaper muhahah
Old 07-09-2003, 11:08 PM
Oh yeah I think I read some wvere this stuff POR-15 was really recommended also...
ok, ill ty the por-15. how does it work and what can I expect from it ?
