Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Salvage yard 700r4 does shift correctly
Old 06-11-2006, 10:45 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by carl holly
i replaced my trans. from a salvage yard it first did not shift right kind of slip between changes 80 mi. later want come out of 1st have i broke it or what can i do it is a 700r4 some one please help
I split this post off from the thread you posted to.... perhaps a better chnace for an answer.
You installed a junk yard tranny. Sorry it does not function correctly.
Is the TV adjusted correctly?
Tranny full of fluid?
Did you flush / clean the tranny cooler system before the current junk yard unit was installed?
Did you install a fresh converter or use the converter from old tranny or converter with junk yard tranny?
How many miles on the junk yard unit?
