Salvage yard 700r4 does shift correctly - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 05:06 AM
New Member
1992 gmc 5.7 2/wd
i replaced my trans. from a salvage yard it first did not shift right kind of slip between changes 80 mi. later want come out of 1st have i broke it or what can i do it is a 700r4 some one please help
Old 06-11-2006, 11:45 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I split this post off from the thread you posted to.... perhaps a better chnace for an answer.
You installed a junk yard tranny. Sorry it does not function correctly.
Is the TV adjusted correctly?
Tranny full of fluid?
Did you flush / clean the tranny cooler system before the current junk yard unit was installed?
Did you install a fresh converter or use the converter from old tranny or converter with junk yard tranny?
How many miles on the junk yard unit?
Old 06-17-2006, 03:04 AM
New Member
trans problems
yes/but mileage unknown the fluid looks dirty to me since I'm going to have to spend some money what would you do this is a nice southern comfort truck i just put a 5.7 crate engion in it im to deep to stop now p-help
Old 06-17-2006, 09:18 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like it is time for a proper rebuild of the tranny.
find a local tranny shop or ask around with street-rodder type friends that may point you to a good tranny person.
good luck , post back when you can.
