same brake hose fitting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2009, 08:48 PM
first things first... im working on a 87 chevy 4x4. im takeing out the 10b and putting in a 14b ff, does anyone know if the rubber brake hose fitting on the 14b is the same as the 10b where they hook up to the factory metal line on the frame? im getting a new line but need to know if i need to buy a conversion line of some sort.
Old 10-31-2009, 08:52 PM
i see now this may be in the wrong place. but im working on the rear end.
Old 11-01-2009, 08:05 AM
fast68 i was told you were the one to ask, have any ideas?
Old 11-01-2009, 02:40 PM
fast68's Avatar
likes chevy trucks & boobies
C/K 5-30 series '73-87 all the same
3/16" on axle tubes
and 1/4" on frame rail
all axle models, gm and dana
only problem you may encounter is that sometimes the tubing yu buy from the store may have thre wrong sie threaded fitting on it so you would need the old one or a new one of the right size
but that rarely happens
happy swapping
Old 11-01-2009, 02:46 PM
thanks, fast68 i knew you would know it.
Old 11-01-2009, 02:47 PM
fast68's Avatar
lol you just got lucky
happy easter
Brake hose routing Q staleg Suspension - Brakes - Steering 4 03-12-2009 12:59 AM
Mo brakes; a saga russerts Suspension - Brakes - Steering 2 03-09-2009 10:28 AM
any sealer impervious to brake fluid? oldguy829 Suspension - Brakes - Steering 16 04-01-2007 02:45 PM
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
