Two things that you must remember when bending pipe this way.
1. The outer radius has to be stretched. 2. The inner radius has to be tucked in. (Slightly) I have always used damp silica sand, heated the outside radius and limited bends to 60 deg. or less. 90 deg. bends have to be cut on the inner radius or tucked in and welded later. If you were mandrel bending, you would be stretching the outside radius as you pulled the pipe in the bender. The inner radius would be supported from crushing. Tubing, depending on size, can be bent using a spring inside to prevent crushing. |
bending tubing.........
Hi,i have taken the tube to be bent,and welded a cap on one end,then fill the tube with DAMP sand,tamp it til its full,then weld a cap on the other end,heating it where you want to bend is helpful..
Great tubing bender. See harbor Freight. http://www.harborfreight.com/garage-...ler-99736.html
this is just something i wanna learn how to do |
| Recent Garage - Tools posts with photos |
| Anybody on here sand bending exhaust? | BAILEIGH | Hotrodders' Lounge | 9 | 01-12-2009 06:35 PM |
| Which kind and where to get sand for my sand blaster | daveh | Garage - Tools | 7 | 02-14-2008 02:04 PM |
| Wet sand, colour sand.... | boofis | Body - Exterior | 9 | 05-25-2005 08:54 PM |
| Bending exhaust pipes | Jim69Mustang | Engine | 5 | 01-28-2005 09:14 AM |
| Fender bending | adb2f | Body - Exterior | 2 | 11-20-2003 11:27 AM |
