sand blasted window glass?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2007, 07:36 PM
New Member
when I had my project car sand blasted some small areas on the window glass got blasted, is there any to repair this. thanks
Old 03-13-2007, 07:41 PM
wavy's Avatar
Last journal entry: Progress on Willys
windows
I have never had a luck with polishing glass that had been sandblasted.
Old 03-13-2007, 11:21 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Thats how they "frost" glass and theres nothing I know of to fix it.
Old 03-14-2007, 11:27 PM
Try toothpaste and lots of elbow grease depending on how deep your glass got etched. Good luck.
Old 03-14-2007, 11:57 PM
powerrodsmike's Avatar
Wiki Edits: 161
The judgement of whether or not glass can be fixed is if it can be felt under your fingernail, it usually can't be polished out without special tools and polishing media.
I bought one of those cesium oxide glass polishing kits from CR lawrence, (automotive glazing supplier), a while back and tried to polish out a little scratch I put in a windshield .It had Cesium Oxide powder and a hard felt wheel that you put in a drill. I think Eastwood might have something like it also.
I was there for hours and got nowhere.
A lapidary supply,(rock and gem polishing supply), or a marble /granite fabricator might be able to set you up with some diamond dust or something similar and a suggestion of what kind of grinding wheel or lapping plate to use to polish your glass with. Maybe a small piece of lapped granite would do. That's what I'd try.
Failing that,
Flow coat it with clearcoat. ?? maybe?
Buy new glass?
Hope this helps,
Mikey
BE different....ACT normal.
Old 03-15-2007, 02:58 AM
I know little about polishing glass but I ran into this on a Mustang windshield I bought at a swap meet, for 10 bucks I thought I would give it a try since it was only a small spot. I used one of those glass polishing kits, I forget the brand name, and I polished forever on that darn thing with no luck. Sometime later while having a windshield replaced on another project I mentioned this to a guy at the glass shop (they also do glass "polishing") and he told me it depends a lot on what it was blasted with because usually sand cuts way to deep to polish out. He said that even if you could cut it deep enough it would probably cause distortion and could even cause tempered glass to break.
Old 03-26-2007, 11:36 PM
ANDAVO1's Avatar
speling errors are intentional
Another option you might have is to sandblast something tasteful (like a car club logo) over the area that is damaged. Kind of like covering a bad tatoo with a better one.
I have tried to polish out sandblast with cerium oxide powder but it will at best look only nominally better.
Old 03-26-2007, 11:54 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
My truck windshield has some deep scratches in it. I post pics on another forum last year and asked about polishing it out. A gentleman who worked in a glass shop for years, said that even the machines they had would not do it.
If you can feel it with your fingernail...its not fixable.
I would imagine that sandblasting goes as deep or deeper than my scratches.
Old 03-27-2007, 12:05 AM
ANDAVO1's Avatar
He was correct. And even if it was polished until it "disappeared", the polished area would be distorted - it would act like a lens. Also, it would take hours upon hours to do, and at shop rates these days the labor could easily cost more than new glass.
Old 03-27-2007, 12:39 AM
BMM BMM is offline
That would actually look really, really cool.
window install Jzarczyn Body - Exterior 10 01-24-2009 11:02 PM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-24-2007 11:40 PM
Basic of Basics - Windshield Installation Kits firebird_red Body - Exterior 15 11-26-2005 09:00 PM
Installing back glass on 66 gto.. help beemdubya Body - Exterior 4 10-12-2005 10:32 PM
windshields bill66di Body - Exterior 15 07-31-2004 07:31 AM
