Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sandblast Cabinet Coating
Old 05-10-2007, 10:04 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Actually the sand eats better at a hard surface than a soft one. The sand just bounces off the soft stuff. That is how they make grave markers. Cut out the letters in rubber sheet, sand blast the stone so it wears away the remove the rubber and you have a tombstone. So maybe some rubber gasket sheet or go to where they make tombstones and see anout that rubber.
