Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sandblast cabinet FINALLY DONE
Old 12-22-2009, 10:07 PM
critter119 critter119 is offline
rodin better than $** any day
used it today had to make a couple adjustments to it. have to figure out a better way to get more air flow through the cabinet, have 10 holes drilled in door, but had to open door to clear dust so i could see, other than that worked awesome. have to get new air compressor motor seized up on it, but that's what a guy gets for using my little one that is made for basically airing up tires manifolded into my bigger one. have to find a replacement pulley for the bigger one as well the pulley center broke when started to use it today.
why is it when you get started on something 9 chances out of 10 something breaks and or goes wrong.
